TABLES1
Bulk Data Entry Defines a tabular function for material and friction property.
Stress-strain curve in elasto-plastic material properties MATS1 and MATHF; Material curves on the MATHE Bulk Data Entry; Tension-Compression Stress-Strain curves on MCIRON Bulk Data Entry, or Friction table versus Pseudo time in nonlinear analysis on the MU1 field of PCONT entry.
| TABLES1 | TID | FLAT | |||||||
| x1 | y1 | x2 | y2 | x3 | y3 | x4 | y4 | ||
| x5 | y5 | etc. | etc. | etc. | etc. | etc. | etc. |
Alternative Format for SCALE and OFFSET
| "SCALE" | scale_x | scale_y | |||||||
| "OFFSET" | offset_x | offset_y | |||||||
Example 1
| TABLES1 | 32 | ||||||||
| -3.0 | 6.9 | 2.0 | 5.6 | 3.0 | 5.6 | ENDT |
Example 2
| SCALE | 1.0 | 2.0 | |||||||
| TID | Table identification
number. No default (Integer > 0) |
| FLAT |
Specifies the handling method for y-values outside the specified
range of x-values in the table.
| x#, y# | Tabular values. No default (Real, or ENDT) |
| SCALE | Flag indicating that the
following two fields are scaling factors. It is an optional scaling
factor continuation line. 12, 13, 14 No default <String> |
| scale_x | The scaling factor for the
data. No default (Real > 0.0) |
| scale_y | The scaling factor for the
| OFFSET | Flag indicating that the
following two fields are offset values. It is an optional offset
continuation line. No default <String> |
| offset_x | The offset value for the
| offset_y | The offset value for the
- must be in either ascending or descending order, but not both.
- Discontinuities between any two points except the two starting points or two end points. For example, in Figure 1 discontinuities are allowed only between points through . Also, if is evaluated at a discontinuity, the average value of is used. In Figure 1, the value of at is .
- At least one continuation entry must be specified.
- Any , pair may be ignored by placing SKIP in either of the two fields used for that entry.
- The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
- For
FLAT=0 (default),
TABLES1 uses the algorithm:Where,
- Input to the table
- Is returned
The table look-up is performed using interpolation within the table and linear extrapolation outside the table using the two starting or end points (Figure 1). The algorithms used for interpolation or extrapolation is:
Where, and follow and .
For FLAT=1, the same algorithm as FLAT=0 is used, except that values outside the range are not extrapolated. The corresponding start or end point y-values are used for all y-values outside the range.
- For TABLES1 referenced by elasto-plastic material property MATS1, additional requirements apply.
- For TABLES1
referenced by cast iron material via MCIRON,
Figure 1. Example of Table Extrapolation and Discontinuity
- Linear extrapolation is not used for Fourier transform methods. The function is zero outside the range of the table.
- For frequency-dependent loads, x# is measured in cycles per unit time.
- Some warning or error messages are issued if table data in input incorrectly. However, since TABLES1 can serve different and distinct purposes, error checking is limited.
- SCALE and OFFSET continuation lines are optional and cannot be put behind actual table data.
- The values of scale_x or scale_y cannot be set to zero.
- By scaling and offset, the new value is scale_x( + offset_x), and scale_y( + offset_y).
