LOADCYN
Bulk Data Entry Used to define the loading, in cyclic symmetry analysis.
LOADCYN | SID | S | SEGID | S1 | L1 | S2 | L2 |
LOADCYN | 11 | 1.0 | 5 | 2.0 | 21 | 1.0 | 22 | ||
LOADCYN | 11 | 1.0 | 4 | 2.0 | 21 | 1.0 | 22 | ||
LOADCYN | 11 | 1.0 | 1.0 | 20 |
SID | Identification number. 2 No default (Integer > 0) |
S | Scale factor. 4
No default (Real) |
SEGID | Segment identification number.5
Si | Scale factor. 4
No default (Real) |
Li | Load identification number. 3
4 No default (Integer > 0) |
- LOADCYN Bulk Data Entry must be referenced by LOAD in the Subcase Information section, in case of cyclic symmetric analysis.
- LOADCYN can share a same ID with other LOADCYN or LOADCYH Bulk Entries. LOADCYN cannot share a same ID with other load set Bulk Data Entries.
- LOADCYN may reference all types of loads, except GRAV and RFORCE. Li may also reference a LOADADD Bulk Data Entry, which does not contain references of GRAV and RFORCE entries.
- The loading defined by
LOADCYN is given by:Where,
- Load vector referenced through Li.
- Number of load vectors.
- The numbering of segment indices is described in CYSYM Bulk Data Entry.
