VISCO
Bulk Data Entry Defines parameters for nonlinear analysis involving time-dependent material behavior.
VISCO ID CETOL TINT
VISCO 2
ID Each VISCO Bulk Data card must have a unique ID.
No default (Integer > 0)
CETOL Tolerance for viscoelastic time integration. Ensures that the viscoelastic/creep strain increment is controlled by the specified tolerance.
If not specified or zero, fixed time integration will be used.
No default (Real ≥ 0) 2
TINT Numerical time integration scheme for solving creep equations. 3
IMPL (Default)
Implicit/backward Euler method
XPL
Explicit/forward Euler method
  1. The VISCO Bulk Data entry can be referenced in the subcase section to specify if viscoelasticity/creep analysis is activated in that subcase.
  2. CETOL is the tolerance to control the time increment size.
    • It ensures the viscoelastic/creep strain increment is controlled by the specified tolerance.
    • In situations where stress significantly affects the creep strain rate, one way to estimate CETOL is to set it equal to an acceptable error in stress divided by a representative elastic modulus.
    • Currently, CETOL is only supported for Small Displacement Nonlinear Analysis (SMDISP).
  3. Creep problems are often solved efficiently by the explicit integration method. This is computationally efficient because, unlike implicit methods, iterations are not required. However, the explicit method is conditionally stable, due to the maximum time step size limitations.
