MOTNG
Bulk Data Entry Defines a constant grid point motion.
MOTNG SID G1 C1 G2 D D0 V0
MOTNG 3 345 3 1.0
SID Load set identification number.
(Integer > 0)
G1 Grid point identification number.
(Integer > 0)
C1 Component number (Integer 1 through 18). The component refers to the direction and type of motion of the grid point G1 in the Basic Coordinate System (not the Local Coordinate System).
G2 Grid point identification number to define relative motion.
(Integer > 0 or blank)
D Scale factor.
(Real)
D0 Initial displacement if motion data is of type velocity or acceleration, ignored otherwise.
V0 Initial velocity if motion data type is acceleration, ignored otherwise.
  1. If G1 and G2 are defined, the motion is a relative motion between the two grid points; if G2 is blank, absolute motion of G1 is defined.
  2. The types and directions of motion for the component numbers are given in the following table.
    Component Number(s) Motion Type Direction(s) of Motion
    1, 2, and 3 Displacement X, Y, Z
    4, 5, and 6 Rotation X, Y, Z
    7, 8, and 9 Translational Velocity X, Y, Z
    10, 11, and 12 Angular Velocity X, Y, Z
    13, 14, and 15 Translational Acceleration X, Y, Z
    16, 17, and 18 Angular Acceleration X, Y, Z
    The component numbers and directions of motion are in the format: 1->X, 2->Y and 3->Z for Displacement and this format is followed for all the types in the table.
  3. This card is represented as a constraint load in HyperMesh.
