Bulk Data Entry Defines a tabular function for use in generating
frequency-dependent and time-dependent dynamic loads. Also contains parametric data for use
with the table.
Specifies the handling method for y-values outside the specified
range of x-values in the table.
=0 (Default)
If an x-value input is outside the range of x-values specified on the
table, the corresponding y-value look up is performed using linear
extrapolation from the two start or two end points.
=FLAT or 1
table, the corresponding y-value is equal to the start or end points,
respectively.
x#,
y#
Tabular values.
Any
x, y pair may be
ignored by placing SKIP in either of the two
fields used for that entry.
No default (Real)
must be in either ascending or descending order,
but not both.
For example, in Figure 1 discontinuities
are allowed only between points through . Also, if is evaluated at a discontinuity, the average
value of is used. In Figure 1, the value of at is .
At least one continuation entry must be
specified.
The end of the table is indicated by the
existence of ENDT in either of the two fields following the last
entry. An error is detected if any continuations follow the entry containing the
end-of-table flag ENDT.
For
FLAT=0 (default),
TABLED2 uses the algorithm:
Where,
Input to the table
Is returned
The table look-up is performed using interpolation within the
table and linear extrapolation outside the table using the two starting or
end points (Figure 1). No warning messages are issued if table data is input incorrectly.Figure 1. Example of Table Extrapolation and
Discontinuity
For FLAT=1, the same
algorithm as FLAT=0 is used, except that
values outside the range are not extrapolated. The corresponding start or
end point y-values are used for all y-values outside the range.
Linear extrapolation is not used for
Fourier transform methods. The function is zero outside the range of the table.
For frequency-dependent loads,
X1 and x# are measured in cycles per
unit time.
This card is represented as a load
collector in HyperMesh.
