PSURF
Bulk Data Entry Defines properties of a contact surface.
PSURF PID EDGECRIT
PID Property identification number.
No default (Integer > 0)
EDGECRIT
Real
Activate edges on the surface that have feature angle greater than or equal to the specified value. Feature angle is the angle between the normal vectors of the two surfaces connected by an edge.
ALL
Indicates that all edges on the surface will be considered.
Default for solid elements = 45.0
Default for shell elements = 179.0
(ALL, or 0.0 ≤ Real ≤ 180.0)
  1. This property can be referenced on the CONTACT Bulk Data Entry.
  2. PSURF is only supported for Explicit Dynamic Analysis (NLEXPL).
