- DOPTPRM, ALMTOSTR
Bulk Data Entry Controls activation of Augmented Lagrange Method (ALM) for Topology Optimization.
- DOPTPRM, APPROX
Bulk Data Entry Switch to select the approximation type for stress/strain responses of shells, composites and 1D elements.
- DOPTPRM, AUTOWGHT
Bulk Data Entry Option to automatically normalize the compliances in the WCOMP response, before applying the weight factors.
- DOPTPRM, BARCON
Bulk Data Entry Controls the internal constraints of PBARL and PBEAML properties during optimization.
- DOPTPRM, BKLOCAL1
Bulk Data Entry Determines the buckling zone of the model.
- DOPTPRM, BKLOCAL2
Bulk Data Entry Specifies the maximum number of elements to represent the buckling zone for local modes.
- DOPTPRM, CHECKER
Bulk Data Entry Controls the checkerboard-like element wise density distribution.
- DOPTPRM, CONTOL
Bulk Data Entry Controls the percentage value of the constraint violation tolerance.
- DOPTPRM, DDVOPT
Bulk Data Entry Control options for discrete design optimization.
- DOPTPRM, DELSHP
Bulk Data Entry The initial fractional move limit for topography/shape design variables (fractional difference between the upper and lower bounds).
- DOPTPRM, DELSIZ
Bulk Data Entry The initial fractional move limit for size design variables.
- DOPTPRM, DELTOP
Bulk Data Entry The initial fractional move limit for topology and free-size design variables.
- DOPTPRM, DESMAX or MAXITER
Bulk Data Entry Defines the maximum number of design iterations.
- DOPTPRM, DISCRETE
Bulk Data Entry Discreteness parameter. Influences the tendency for elements in a topology optimization to converge to a material density of 0 or 1.
- DOPTPRM, DISCRT1D
Bulk Data Entry Discreteness parameter for 1D elements.
- DOPTPRM, ESLMAX
Bulk Data Entry Maximum number of outer design loops in the design of multibody dynamic systems and for nonlinear optimization using ESLM.
- DOPTPRM, ESLSOPT
Bulk Data Entry Controls the time step screen strategy in the design of multibody dynamics systems.
- DOPTPRM, ESLSTOL
Bulk Data Entry Controls the tolerance for screening out time steps in the design of multibody dynamic systems.
- DOPTPRM, GBUCK
Bulk Data Entry Controls global buckling constraint.
- DOPTPRM, GEOMSENS
Bulk Data Entry Activates geometric sensitivity influence in topography or free shape optimization.
- DOPTPRM, MATINIT
Bulk Data Entry Defines the initial material fraction.
- DOPTPRM, MAX_BUCK
Bulk Data Entry Controls maximum number of buckling eigenvalues to be considered for each buckling subcase in the optimization problem.
- DOPTPRM, MINDENS
Bulk Data Entry Sets the minimum element material density.
- DOPTPRM, MINDIM
Bulk Data Entry Specifies the minimum diameter of members formed in a topology optimization.
- DOPTPRM, MMCHECK
Bulk Data Entry Parameter to ensure a checkerboard-free solution.
- DOPTPRM, OBJTOL
Bulk Data Entry Relative convergence criterion.
- DOPTPRM, OLDPEN
Bulk Data Entry Controls the mass penalization method for Topology Optimization.
- DOPTPRM, OPTMETH
Bulk Data Entry Options to choose the optimization algorithm.
- DOPTPRM, OPTIMOMP
Bulk Data Entry Controls activation of OpenMP parallelization for enhanced computational efficiency.
- DOPTPRM, PNORM
Bulk Data Entry Specifies the value of the power (or penalty) , used in the NORM Method for certain response calculations in Topology, Free-size, and Lattice Structure Optimization.
- DOPTPRM, REMESH
Bulk Data Entry Specifies if the remeshing process will be activated when the optimization runs into element quality error.
- DOPTPRM, SHAPEOPT
Bulk Data Entry Defines an optional parameter to select an alternative shape optimization algorithm.
- DOPTPRM, TMINPLY
Bulk Data Entry Defines the minimum ply thickness allowed for all plies of PCOMPs selected by DSIZE or DTPL design variable definitions.
- DOPTPRM, TOPDISC
Bulk Data Entry Activates the improved discrete topology optimization formulation.
- DOPTPRM, TOPDV
Bulk Data Entry Activates an alternative method for the generation of topology and level-set design variables.
- DOPTPRM, TOPRST
Bulk Data Entry This parameter should be defined in the subsequent restart optimization model.
