DOPTPRM, BKLOCAL2
Bulk Data Entry Specifies the maximum number of elements to represent the buckling zone for local modes.
Parameter Values Description
BKLOCAL2 <Integer ≥ 0>
No default
If the size of the buckling zone (determined by BKLOCAL1), for any modes, goes over the specified number of elements, then they will be considered as global buckling modes.
The constraint bound for local mode will be specified in 6th field of DCONSTR.
