DOPTPRM, OPTIMOMP
Bulk Data Entry Controls activation of OpenMP parallelization for enhanced computational efficiency.
Parameter Values Description
OPTIMOMP <YES, NO> Controls activation of OpenMP parallelization for enhanced computational efficiency while solving the optimization problem using DUAL2, MFD, or SQP algorithms:
YES (Default)
Parallel computation is activated.
NO
Parallel computation is not active.
  1. Parallel computation is active by default and can be turned off using DOPTPRM,OPTIMOMP,NO.
  2. Parallelization applies to both SMP and MPI runs.
