DOPTPRM, OBJTOL
Bulk Data Entry Relative convergence criterion.
Parameter Values Description
OBJTOL Real > 0.0
Default = 0.005
If relative change in the objective function between two design iterations is less than OBJTOL, then optimization stops.
A relative change in the objective function of 0.005 is the same as a 0.5% change in the objective function.
For Lattice Structure Optimization, the default is set to 0.001.
