DOPTPRM, TOPRST
Bulk Data Entry This parameter should be defined in the subsequent restart optimization model.
| Parameter | Values | Description |
| TOPRST | <STRICT, ADVNOR,
ADVRES> Default = If this parameter is not specified in the input file, then the advanced topology restart feature is not activated and regular restart (STRICT) is the default. |
- DOPTPRM,TOPDV,ALTER should be specified in the initial optimization model that generates the restart files for the advanced topology or level-set restart.
- For additional information, refer to Advanced Restart for Topology and Level-set Optimization.
