HOURGLS
Bulk Data Entry Defines hourglass control parameters to reduce spurious zero-energy modes in elements with reduced integration.
Attention: Valid for Explicit Analysis only
HOURGLS HGID HGTYP HGFAC
HOURGLS 2 2 .05
HGID Hourglass control card identification number
No default (Integer > 0)
HGTYP Hourglass control types 2
1
Flanagan-Belytschko viscous form (available for both solids and shells).
2 (Default for MAT1/MATS1)
For solids: Puso enhanced assumed strain stiffness form (available only for eight-noded CHEXA elements). 4
For shells: Flanagan-Belytschko stiffness form (available for shells only).
4 (Default for MATHE)
Reese enhanced assumed strain stiffness form (available only for eight-noded CHEXA elements). 2 3
HGFAC Scale factor for hourglass control forces
Default = 0.1 for HGTYP=1 (0.05 < HGFAC < 0.15)
Default = 0.05 for shells with HGTYP=2 (0.0 < HGFAC < 0.1)
Default = 1.0 for solids with HGTYP=2 (0.0 < HGFAC ≤ 1.0)
Default = 0.01 for HGTYP=4 (0.0 < HGFAC < 0.1)
  1. HOURGLS Bulk Data Entries can be selected in element property definition to disable default hourglass control parameters.
  2. HGTYP=1 and HGTYP=2 are available for MAT1/MATS1. For MATHE, only HGTYP=2 and HGTYP=4 are available. In most situations, HGTYP=4 exhibits good performance for MATHE. HGTYP=4 is only available for MATHE materials.
  3. HOURGLS entry when referenced on HGID field of the corresponding PSOLID, PLSOLID, or PSHELL entries will overwrite the values defined via PARAM, HOURGLS.
  4. When HGTYP=2 is defined, the input HGFAC is neglected in the presence of MAT1/MATS1 and a fixed value of HGFAC=1.0 is used.
