RANDT1
Bulk Data Entry Defines time lag constants for use in random analysis autocorrelation function computation.
RANDT1 SID N T0 TMAX
RANDT1 5 10 3.2 9.6
SID Random analysis set identification number.
(Integer > 0)
N Number of time lag intervals.
(Integer > 0)
TO Starting time lag.
(Real ≥ 0.0)
TMAX Maximum time lag.
(Real > TO)
  1. At least one RANDPS entry must be present with the same set identification number.
  2. The time lags defined on this entry are given by:
    T i = T o + T max T o N ( i 1 ) , i = 1 , N + 1
  3. Similar to RANDPS Bulk Data Entries, the RANDT1 Bulk Data Entries can be referenced either by:
    • The RANDOM Subcase or Case Control Entry.
    • A SET I/O Options Entry that is then referenced by a RANDOM Case Control Entry. 4
    • A SET Bulk Data Entry with TYPE=MODE that is then referenced by a RANDOM Case Control Entry. 4
  4. If a SET entry is used to reference multiple RANDPS data, then the RANDT1 entry with the smallest ID from set of referenced entries will be selected for the analysis.
    For example:
    RANDOM=2
    SET 2 = 5,6,7
    BEGIN BULK
    RANDPS,5
    RANDPS,6
    RANDPS,7
    RANDT1,5 → This RANDT1 entry is selected for analysis.
    RANDT1,6
