FREQ1
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
FREQ1 | SID | F1 | DF | NDF |
FREQ1 | 6 | 2.9 | 0.5 | 13 |
SID | Set identification
number. No default (Integer > 0) |
F1 | First frequency in
set. No default (Real ≥ 0) |
DF | Frequency
increment. No default (Real > 0.0) |
NDF | Number of frequency
increments. Default = 1 (Integer > 0) |
- FREQ1 entries must be selected with the I/O Options or Subcase Information command FREQUENCY = SID.
- The units for F1 and DF are cycles per unit time.
- The frequencies defined by this entry are
given by fi = F1
+ DF * (i -1)
where i = 1 to (NDF + 1).
- All FREQi entries with
the same set identification numbers will be used. Duplicate frequencies will be
ignored.
and
are considered duplicated if:Where,
- DFREQ
- User parameter with a default of 10-5 *
- The maximum and minimum excitation frequencies of the combined FREQi entries
- This card is represented as a load collector in HyperMesh.
