CONM2
Bulk Data Entry Defines a concentrated mass at a grid point of the structural model.
Attention: Valid for Implicit
and Explicit Analysis
CONM2 | EID | G | CID | M | X1 | X2 | X3 | ||
I11 | I21 | I22 | I31 | I32 | I33 | ||||
RAYL | ALPHA |
CONM2 | 2 | 15 | 49.7 | ||||||
16.2 | 16.2 | 7.8 |
EID | Unique element
G | Grid point identification
CID | Coordinate system
identification number. Default = 0 (Integer ≥ -1) |
M | Mass value. No default (Real) |
X1, X2, X3 | Offset distance from the
grid point to the center of gravity of the mass in the coordinate
system defined by CID, unless
CID = -1, in which case
X1, X2, and
X3 are the coordinates (not offsets) of the
center of gravity of the mass in the basic coordinate
system. Default = 0.0 (Real) |
Iij | Mass moments of inertia
measured at the mass center of gravity.
RAYL | Continuation line flag for material-dependent Rayleigh damping 5 | |
ALPHA | Rayleigh damping
coefficient for the mass matrix 5 Default = 0.0 (Real ≥ 0.0) |
- If the continuation is omitted, all rotary inertia is assigned zero values.
- The form of the inertia matrix about its
center of gravity is:Where,
- M
- Input mass value
- Iij
- Input inertia values
- X1, X2, and X3
- Offsets
- If CID = -1, the offsets are computed internally as the difference between the grid point location and X1, X2, and X3. The grid points may be defined in a local coordinate system, in which case the values of must be in a coordinate system that parallels the basic coordinate system.
- If CID > 0, then X1, X2, and X3 are defined by a local Cartesian system, even if CID references a spherical or cylindrical coordinate system.
- For material-dependent Rayleigh
damping, the equivalent viscous damping,
, is defined as:
- Defined on the RAYL continuation line on the material entry
- Mass matrix
- Nonlinear Transient Analysis
- This card is represented as a mass element in HyperMesh.
