ROTOR
Bulk Data Entry 3D Rotor Definition. Specifies list of sets, elements or properties that comprise the rotor 3D model.
ROTOR | ROTORID | ||||||||
LTYPE | ID1 | ID2 | ID3 | etc. | |||||
AXIS | GID1 | GID2 |
ROTOR | 10 | ||||||||
SET | 1 | THRU | 3 | ||||||
AXIS | 101 | 102 |
Definition
ROTORID | Identification number
of a rotor. No default (Integer > 0) |
LTYPE | Indicates the item
type in the list references elemental set IDs, element IDs or
property IDs.
No default (Character) |
IDi | IDs of sets, elements
or properties comprising the rotor. No default (Integer > 0) |
AXIS | Defines grid points which define the axis of rotation. | |
GID1, GID2 | IDs of grids
comprising the axis of the rotor. No default (Integer > 0) |
- Fixed reference frame method is adopted for 3D rotor dynamic analysis via the ROTOR Bulk Data Entry.
- Supported element types:
- 0D elements : CONM1, CONM2
- 1D elements : CBEAM, CBAR
- 3D elements : CHEXA, CPENTA, CTETRA, CPYRA
- The THRU option is supported in lists of elemental set IDs, element IDs and property IDs. Different LTYPE lists can be used together.
- 1D rotors can be defined via the ROTORG Bulk Data Entry.
- For more information, refer to Rotor Dynamics in the User Guide.
