DOBJREF
Bulk Data Entry Defines a response and its reference values for a minmax (maxmin) optimization problem.
DOBJREF | DOID | RID | SID | NEGREF / LID | POSREF / UID | LOWFQ | HIGHFQ |
Example 1
DOBJREF | 22 | 3 | ALL | -1.0 | 1.0 | ||||
DOBJREF | 22 | 5 | ALL | -1.0 | 1.0 |
DRESP1 | 3 | TOP | DISP | 3 | 488 | ||||
DRESP1 | 5 | BOTTOM | DISP | 3 | 601 |
Example 2
DOBJREF | 23 | 14 | ALL | -1.0 | 1.0 |
DOID | Design objective identification number. (Integer > 0) |
RID | DRESP1 or
DRESP2 identification number. (Integer > 0) |
SID | Subcase identification
number.
(Integer > 0) |
NEGREF/ LID |
POSREF/ UID |
LOWFQ | Lower bound on a loading frequency range. Default = 0.0 (Real ≥ 0.0) |
HIGHFQ | Upper bound on a loading frequency range. Default = 1.0E+20 (Real ≥ LOWFQ) |
- The same DOID can be used for multiple DOBJREF entries. If only one DOID is used, only one MINMAX=DOID entry is needed in the Subcase Information section.
- The use of reference values allows users
to set up general minmax problems involving different responses with different
magnitudes. For these problems, the objective can be defined as:Where,
- Response values
- Are corresponding reference values, which can take different values depending on whether the response is positive or negative.
- Typically, the target value or constraint value of a response can be used as its reference value. So, instead of the traditional optimization problem where there is a single objective and multiple constraints, the problem may be formulated as a minmax (maxmin) optimization, where all the responses which were previously constrained are defined as objectives and their bounds are used as reference values. This works toward pushing the maximum ratio of response versus bound value as low as possible, thus increasing the safety of the structure.
- LOWFQ and HIGHFQ apply only to response types related to a frequency response subcase (DRESPi, RTYPE = FRDISP, FRVELO, FRACCL, FRSTRS, FRSTRN, FRFORC, FRPRES and FRERP). The reference values NEGREF and POSREF are applied only if the loading frequency falls between LOWFQ and HIGHFQ. If ATTB of DRESP1 specifies a frequency value, LOWFQ and HIGHFQ are ignored.
- LID and UID identify a loading frequency dependent tabular input using TABLEDi. They are applied analogous to LOWFQ, HIGHFQ. 4
- The recommended setup to define Minmax or
Maxmin models which reference several responses is:
- Create multiple DOBJREF entries with the same DOID
- Each DOBJREF entry references one response
- MINMAX or MAXMIN entry should reference the single ID corresponding to all DOBJREF entries.
- This card is represented as a design objective reference in HyperMesh.
