MOTNJG
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
| MOTNJG | ID | TID | TSTIME | ||||||
| JID1 | DOF | VALUE | SET | ||||||
| JID2 | DOF | VALUE | SET | ||||||
| etc. |
| MOTNJG | 3 | ||||||||
| 2 | 1 | 1.0 | SET | ||||||
| 3 | 2 | 2.0 |
| ID | Motion set identification
number. (Integer > 0) |
| TID | Identification number of a
TABLEDi entry that defines motion scale
factors versus time. The motion in the VALUE
field is multiplied with the scale factors to determine
time-dependent motion on the joint degrees of freedom. Default = blank (Integer > 0) |
| TSTIME | Switch for time duration
of the data from the table defined in TID. 3
Default = TOT |
| JIDi | Identification number of a JOINTG Bulk Data Entry on which the motion is to be applied. | |
| DOF | Degree of freedom
component number. No default (1 ≤ Integer ≤ 6) |
| VALUE |
No default |
| SET | Keyword indicating that
the corresponding JID refers to an element set
which contains a set of JOINTG entries. Default = blank |
- The MOTNJG Bulk Data Entry can be referenced in the corresponding MOTNJG Subcase Information Entry.
- If a MOTNJG Bulk Data Entry is not referenced in any subcase, then it is not used in the solution.
- TID and
TSTIME are supported for:
- Implicit small and large displacement nonlinear static analysis.
- Implicit small and large displacement nonlinear transient analysis.
- Explicit dynamic analysis.
- MOTNJG is also supported for normal modes (MODES) analysis. Any nonzero motion value is ignored, and zero motion is always applied instead. Two or more subcases can reference different MOTNJGs, but the motions must be applied on the same joint DOFs.
- MOTNJG with JID and SET are supported for both implicit and explicit analyses.
