SPCOFF1
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
SPCOFF1 C G1 G2 G3 G4 G5 G6 G7
G8 G9 etc.
Alternate Format
SPCOFF1 C G1 THRU G2
SPCOFF1 3 22 12 52 7
Alternate Example
SPCOFF1 4 9 THRU 52
Definition
C Component numbers.
(Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points).
Gi Grid or scalar point identification numbers.
(Integer > 0 or “THRU”)
  1. Degrees-of-freedom on this entry will be excluded from AUTOSPC.
  2. If both SPC and SPCOFF1 are defined for the same degree-of-freedom, then SPC takes priority.
  3. For the THRU option, all grid points numerically in between G1 and G2 are not required to exist.
