CHGVOL
Bulk Data Entry Defines the charge density on a volume of CHEXA, CPENTA, CTETRA, or CPYRA solid elements.
CHGVOL | SID | EID | Q |
CHGVOL | 2 | 1106 | 10.0 |
SID | Load identification
number (Integer > 0) |
EID | Element identification
Q | Charge volume density No default (Real) |
- Equivalent grid point charge densities are computed by linear (or bi-linear) interpolation of load intensity, followed by numerical integration using isoperimetrical shape functions. Uniform load intensity does not necessarily result in equivalent grid point loads.
- For more information, refer to Piezoelectric Analysis in the User Guide.
