CURRENT
Bulk Data Entry Defines a static point current at a grid or a set of grids, by specifying a vector, in Electrical analysis.
CURRENT | SID | GID/GSETID | VAL | ||||||
GSET |
CURRENT | 2 | 5 | 2.3 |
SID | Entry identification
number. (Integer > 0) |
GID/GSETID |
VAL | Point current
magnitude. (Real) |
GSET | Flag which indicates that the GID/GSETID field is identified as a set of grids at which the forces are applied. |
- This card is a steady current applied to a grid point. A positive value means the current flows into the conductor and a negative value means the current flows out of the conductor.
- String-based labels allow for easier visual identification of sets when being referenced by other cards. Refer to String Label Based Input File for additional information.
- This card is represented as an electrical current load in HyperMesh.
