PARAM, HOURGLS
Bulk Data Entry Controls the hourglass type.
Parameter | Values | Description |
HGTYP | <1, 2, 4> | Hourglass control types.
HGFAC |
Scale factor for hourglass control forces. |
- An HOURGLS Bulk Data Entry referenced on the HGID field of PSOLID, PLSOLID, or PSHELL will overwrite the values defined via PARAM,HOURGLS.
- When HGTYP=2 is defined, the input HGFAC is neglected in the presence of MAT1/MATS1 and a fixed value of HGFAC=1.0 is used.
