PARAM, ORIGK4
Bulk Data Entry The value of PARAM,ORIGK4 is used to replace the GE damping field on any material Bulk Data Entry referenced by superelements.
Parameter | Values | Description |
ORIGK4 | <REAL> Default = Blank |
The value of PARAM,ORIGK4 is used to replace the GE damping field on any material Bulk Data Entry referenced by superelements. |
- If this parameter is not specified, then the corresponding GE damping values on the material entries are not replaced.
