PARAM, RFIOUT
Bulk Data Entry Controls the output of modal super element for use in the RecurDyn multibody dynamics software from FunctionBay.
Parameter Values Description
RFIOUT <YES, NO> This information is written to the .rfi file. This should be used with CMSMETH CBN and ASET DOF for the connection points.
YES
The modal super element is output to the .rfi file.
NO (Default)
The .rfi file is not created.
  1. This .rfi file can be created only by OptiStruct executables running on 64-bit Windows machines. This file cannot be created while using OptiStruct on Linux or Mac OS X machines.
