PARAM, RBD2ELEM
Bulk Data Entry Used to control how RBODY entries in the model are internally processed.
Parameter Values Description
RBD2ELEM <YES, NO>
YES
Enhances the performance of RBODY entry processing in the model by creating a single internal element to simulate all elements inside the RBODY. RBODY entries are simulated by internally do not create a large number of constraints, which improves performance.
NO (Default)
RBODY processing is conducted using the regular method.
  1. If no value is specified, RBODY processing is conducted using the regular method.
