PARAM, FASTFR
Bulk Data Entry Controls the activation of a faster, alternative method (FASTFR) for Modal Frequency Response Analysis.
| Parameter | Values | Description |
| FASTFR | <AUTO,
YES, NEW or
NO> Defaults:
- If PARAM, FASTFR,YES is specified in a Modal FRF model which does not support FASTFR, then the model is automatically switched to the standard method and a WARNING is printed in the OUT file.
