PARAM, FASTINIT
Bulk Data Entry Controls the initialization of contact status in Fast Contact Analysis.
Parameter Values Description
FASTINIT <0, 1>
0 (Default)
The final contact status of the preceding subcase with the same boundary conditions are used as the initial status for the current subcase.
1
Contact status is not inherited between consecutive subcases with the same boundary conditions.
  1. PARAM, FASTINIT=0 might help reduce the number of iterations for the current subcase and this would not affect the results.
  2. The parameter is valid only for Fast Contact Analysis.
