PARAM, KDAMP
Bulk Data Entry Enters viscous modal damping into the stiffness matrix as structural damping.
| Parameter | Values | Description |
| KDAMP | <-1, 1 > |
- To achieve identical displacements in Modal frequency response or Modal
                    transient analyses when the SDAMPING Subcase Information Entry is used instead of
                        PARAM, G, the steps described here can
                    be followed: - The TYPE field in the TABDMP1 or TABDMP2 Bulk Data Entry should be set to CRIT. This TABDMP1 or TABDMP2 Bulk Data Entry is referenced by the SDAMPING Subcase Information Entry.
- Set the damping value (field ) in the TABDMP1 or TABDMP2 Bulk Data Entry equal to half of the value of PARAM, G (that is set the constant value to ).
- Set PARAM,KDAMP,-1 (See description above).
