Bulk Data Entry Specifies the reference acoustic power value
used to calculate Acoustic Power (ACPOWER) in decibels (dB).
| Parameter |
Values |
Description |
| ACPREFDB |
Real > 0.0 Default =
1.0 |
The Acoustic Power
(ACPOWER) in decibels can be calculated using
the following equation:Where,
- Acoustic power in decibels.
- Reference acoustic power value specified using this
parameter.
ACPOWER output in dB scale is
currently only available in PUNCH format. |
