PARAM, HGHCMPOK
Bulk Data Entry Used to turn on or off the check for negative and very large compliance values.
Parameter | Values | Description |
HGHCMPOK | <YES,
NO> Default: NO, if present in the model without any value. NO, if not specified in the model. |
- High compliance checking will be skipped for Equivalent Static Load (ESL) subcases.
