Bulk Data Entry This parameter controls the method used for modal frequency response solution when
frequency-dependent materials are present and AMSES is used as the eigensolver.
Parameter |
Values |
Description |
AMSFRMAT |
<YES, NO> Default =
NO
- YES
- An alternate method is activated for modal frequency
response solutions when a large number of
frequency-dependent materials (> 1000 dof) are
present and AMSES is used as the eigensolver. This
alternate method can help improve the performance of
the modal frequency response solution.
- NO
- The alternate method is not activated.
