PARAM, LSNLEXP
Bulk Data Entry In the small displacement NLSTAT solution that has difficulties converging, the “expert system” will try, among other remedies, activation of Line Search.
Parameter | Values | Description |
LSNLEXP | <YES, NO, AUTO> |
- When Line Search is activated explicitly by MAXLS > 0 on the NLPARM card, it will be active (where applicable) irrespective of this parameter.
