PARAM, CDITER
Bulk Data Entry Controls the activation of MPC-based Fast Contact Analysis.
| Parameter | Values | Description |
| CDITER | <Integer ≥ 0> Default = 0 |
Controls the activation of MPC-based Fast Contact Analysis. It also specifies the maximum number of iterations allowed. If this parameter does not exist in the input deck (default), MPC-based Fast Contact is not activated. |
