PARAM, MBDH3D
Bulk Data Entry Choose the type of the results output to the .h3d file for MBD analyses.
| Parameter | Values | Description |
| MBDH3D | <NODAL, MODAL, BOTH, or NONE> | This parameter controls
the type of results output to the .h3d results
format for MBD analyses.
- If the HyperMesh output format is requested, nodal based results will be output to the .res file, regardless of this parameter setting.
