PARAM, NOUTCYC
Bulk Data Entry Frequency for output control. OptiStruct will write results to the .out file in every NOUTCYC step.
Attention: Valid for Explicit
Analysis only
| Parameter | Values | Description |
| NOUTCYC | (Integer > 0) Default = 100 |
Frequency for output control. OptiStruct will write results to the .out file in every NOUTCYC step. |
