Bulk Data Entry Generates flexh3d files for flexible bodies in
an MBD analysis.
| Parameter |
Values |
Description |
| FLEXH3D |
<AUTO,
YES, or NO> |
- AUTO (Default)
- Flexh3d files are generated only for those flexible
bodies for which no previously generated flexh3d file
exists. Previously generated flexh3d files are checked
for validity; if the file is valid for the corresponding
flex-body definition, the run will continue using the
existing flexh3d file. If the file is found to be
invalid (has a different mass or the wrong number of
grids), an error termination will occur.
- YES
- Flexh3d files are generated for all flexible bodies,
overwriting existing files (if present).
- NO
- Flexh3d files are not generated. The run makes use of
previously generated files. An error termination will
occur if no such files exist.
