Bulk Data Entry Outputs the strength ratios for composite
        elements that have failure indices requested.
                            | Parameter |
                            Values |
                            Description |
                            | SRCOMPS |
                            <YES,
                                    NO, blank> |
                                        - YES
                                        - The strength ratios are output for composite elements
                                            that have failure indices requested. (The Output formats
                                            currently supported are: H3D, HM, OP2, PCH and
                                            OPT).
                                        - NO (Default), blank
                                        - The strength ratio will not be output.
                - The Strength Ratios that are output as a result of
                        PARAM, SRCOMPS, YES
                    depend on the specified Failure Theory. The following equations show the
                    relationship between the Failure Index and the Strength Ratio for different
                    Failure Theories.
                        - Hill Failure
                                Theory:
                        - Hoffman Failure Theory:
There is no direct relationship between the Strength Ratio and
                                Failure Index (refer to Composite Laminates in the User
                                    Guide for more information). OptiStruct solves the quadratic equation to
                                find the strength ratio.
                        - Tsai-Wu Failure Theory:
                                Failure Index. (refer to Composite Laminates in the User
                        - Maximum Stress (Strain) Failure
                                Theory:
                        - Transverse Shear Failure
                                Theory:
                        - Cuntze Failure
                                Theory:
