PARAM, ELASSTIF
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PELAS Bulk Data Entry.
This parameter can accept two arguments. If only one argument is specified, the same value is used for the second argument.
PARAM, ELASSTIF, <ELASSTIFT>,
<ELASSTIFR>
Parameter | Values | Description |
ELASSTIFT | <Real Number ≥
0.0> No default |
This
parameter controls the value of field K in
the PELAS scalar elastic
property entry and the
CELAS2/CELAS4 scalar
spring property and connection entries.
ELASSTIFR | <Real Number ≥
0.0> Default = <ELASSTIFT> |
- Any value on the field K on the PELAS or CELAS2/CELAS4 entry which exceeds ELASSTIFT or ELASSTIFR, respectively will be replaced by ELASSTIFT or ELASSTIFR.
- Either ELASSTIFT or ELASSTIFR (or both) can be set to 0.0. This will disable stiffness control for the corresponding translational or rotational stiffnesses.
- Defaults:
- If ELASSTIFT is input without specifying a value, then OptiStruct will error out (no default). The default for ELASSTIFR is ELASSTIFT.
- If PARAM, BUSHSTIF is not included in the deck, the elastic property value (Field K) is not replaced regardless of its value (no stiffness control).
- This parameter cannot be used to modify the values specified on CELAS2F, CELAS4F, or PELASFX Bulk Data Entries.
