PARAM, MFILTER
Bulk Data Entry Defines a threshold for the mode tracking matrix to check eigenvector correspondence.
| Parameter | Values | Description |
| MFILTER | <0.0 ≤ real number ≤
1.0> Defaults:
This parameter defines a
correspondence. This can also be controlled via the
MODTRAK
Bulk
Data
Entry. If an entry of the mode tracking matrix is greater than the specified threshold, the eigenvectors of previous and current iterations (corresponding to the row number and column number of the entry) are assumed to have correspondence. If PARAM, TRAKMETH or the TRAKMETH field on the MODTRAK Bulk Data Entry is set to 0 , the mass matrix based cross-orthogonality criterion (CORC) is used to check for eigenvector correspondence, and the filtering threshold (MFLITER) is set to 0.7. If PARAM, TRAKMETH or the TRAKMETH field on the MODTRAK Bulk Data Entry is set to 1, the modal assurance criterion square root (MACSR) is used, and the filtering threshold (MFILTER) is set to 0.7. If PARAM, TRAKMETH or the TRAKMETH field on the MODTRAK Bulk Data Entry is set to 2, the modal assurance criterion (MAC) is used and the filtering threshold (MFILTER) is set to 0.5. |
