PARAM, CK2
Bulk Data Entry Scale factor for direct input stiffness matrices.
Parameter Values Description
CK2 <Real>
Default = 1.0
CK2 specifies factors for the direct input stiffness matrix. The total stiffness matrix is:
K jj = K jj x + CK 2 * K jj 2
Where,
K jj 2
Is selected in the Subcase Information command K2GG.
K jj x
Is generated from structural element entries in the Bulk Data section.
