PARAM, COMP2SHL
Bulk Data Entry Results of homogenization of composite properties.
| Parameter | Values | Description |
| COMP2SHL | <YES, NO, or BULK> |
- The equivalent shell and materials represent composite properties as they are defined in the input deck. In optimization runs involving composites, OptiStruct internally adjusts and changes the composite properties. Such changes are not reflected in the equivalent shell results printed by this command.
