PARAM, NLMON
Bulk Data Entry This parameter activates Nonlinear Results Monitoring. Currently, only displacement results monitoring is available.
| Parameter | Values | Description | |
| NLMON | VALUE1 | <DISP,
NO> Defaults:
| VALUE2 | <OVERWRITE> Default = Blank (New Issue) |
If OVERWRITE is specified, the results from the previous increment are overwritten with results from the current/latest increment. Also, when OVERWRITE is specified, each subcase has its own separate _nl_sub#.h3d file which contains the results data, and a single _nl_model.h3d file which contains the model data. | |
- The generated _nl.h3d file and diagnostic
information in the _nl.out file can be further analyzed
using the script
os_out_file_parser.tcl. For further information on using this script, refer to the NLMON Bulk Data Entry. - PARAM,NLMON is overridden by NLMON Bulk and Subcase Entry pairs for any specified subcase. Supported subcases that do not contain the NLMON Subcase Entry will be influenced by PARAM,NLMON.
- NLMON is currently supported for Small and Large Displacement Nonlinear Static and Large Displacement Nonlinear Transient analysis only. By extension to Nonlinear Transient Analysis, it is also supported for Structural Fluid-Structure Interaction (FSI).
