Bulk Data Entry Used to modify the tolerance value for
symmetric beams when they are used for rotor modeling.
Parameter |
Values |
Description |
SBTOLRTR |
<Real > 0.0> Default
= 1.0E-6 if parameter is not present in the model. |
The tolerance value (
) is used in the following checks:
- Relative Tolerance for Bending Stiffness
- Tolerance for Shear Correction Factor
- Tolerance for Neutral Axis Location
(at locations A and
B)
- Tolerance for Offset Vectors
(at locations A and
B)
