PARAM, BUSHTLMT
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT).
| Parameter | Values | Description |
| BUSHTLMT | <Real Number >
                                    0.0> Default = 1E+07  |
                            This parameter is used to issue a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT). |
- This check is overridden when PARAM, BUSHSTIF is used to control the maximum stiffness value.
