PARAM, VISC2MAT
Bulk Data Entry Used to convert viscous damping matrix to material damping matrix.
Parameter | Values | Description |
VISC2MAT | Real No default |
This value, when multiplied by the viscous damping matrix, transforms the viscous damping matrix into the material damping matrix. |
- This parameter is only applicable to complex eigenvalue analysis.
