PARAM, SIMDRIVE
Bulk Data Entry Controls the output of the <filename>._simdrive.h3d file directly from OptiStruct.
| Parameter | Values | Description |
| SIMDRIVE | <YES,
BOTH> Default: When this parameter is not defined in the input file, the corresponding SIMDRIVE H3D file is not generated. If this parameter is input without a value, an error is issued. |
from OptiStruct.
