PARAM, DISJOINT
Bulk Data Entry Used to allow AMLS to handle disconnected parts. This can also be accomplished with PARAM, AMLSUCON.
| Parameter | Values | Description |
| DISJOINT | <Integer> Default = NONE |
DISJOINT is used to allow
also be accomplished with PARAM,AMLSUCON. PARAM,
DISJOINT should be set to one larger than
the number of disconnected parts as determined by
AMLS. PARAM,
DISJOINT causes the environment variable
PARAM, DISJOINT can be set to a real value for compatibility, but it is recommended to use an integer value. |
