PARAM, INRELOUT
Bulk Data Entry Controls the output of inertia relief-corrected applied loading in conjunction with OLOAD request.
Parameter Values Description
INRELOUT <YES, NO>
Default = NO
YES
The OLOAD output for inertia relief analysis includes inertia relief correction.
NO
The OLOAD output for inertia relief analysis does not include inertia relief correction for:
  • PARAM,INREL,-2 with internally generated constraints.
Note: the OLOAD outputs for the following two cases always include inertia relief correction regardless of PARAM,INRELOUT:
  • PARAM,INREL,-1
  • PARAM,INREL,-2 with internally generated SUPORT degrees of freedom.
