Bulk Data Entry Activates Large Displacement Nonlinear
Analysis.
| Parameter |
Values |
Description |
| LGDISP |
<0,
-1,
1> |
- 0 or -1 (Default)
- Large displacement nonlinear analysis is deactivated
(Small Displacement Nonlinear Analysis is the default
for static analysis, while
LGDISP=1 is
currently mandatory for nonlinear transient analysis).
The corresponding nonlinear solution parameters can be
specified in the NLPARM and NLADAPT Bulk Data Entries.
- 1
- Large displacement nonlinear analysis is activated. The
