PARAM, UFREQPCH
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the upper bound of frequency, for PCH output.
Parameter | Values | Description |
UFREQPCH | <Real> (Hertz) No default (See Comment 3) |
Modes with frequencies above this value are not output in the PCH file. |
- This parameter only applies to PCH output and does not affect the calculations during the simulation.
- This parameter works for complex eigenvalue and normal mode analysis, but only for the structural modes or coupled modes.
- If PARAM, UFREQPCH is used without specifying a value, the simulation will error out.
